Custom switch on PC case
Go to solution Solved by thrasher_565,
3 minutes ago, Chronnay said:
Hello modders!
Do I need to protect the switch-case contact from short-circuit (or anything else)? Pictures of switch below
pc power switch is momentary meaning its on for a second then off.
Hello modders!
3 hours ago, Chronnay said:
Thanks for a quick reply and answer.
Off-topic question is it possible to turn off the computer with the same key switch?
ya pc use the same switch to turn it on and off (some cases you have to hold it to turn off)
Edited by thrasher_565
Usually, cables are isolated but you could use shrink tubes (not sure if it is the right translation).
It could work if you move the key and move it right back... Not sure if that is something you would want.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
