Hi, I’m currently undergoing a design problem and need to collect some research.
If you could take 2 minutes to answer this questionnaire it would be greatly appreciated.
https://forms.gle/HruJAZstVHJK3WEE6
If you have any suggestions feel free to PM me
thanks
Edited by TVwazhere
Remove Email, offered alternative contact
https://linustechtips.com/topic/1275861-pc-case-design-project/
Quote
When selecting components ( of a certain performance level) for a build, what do you look for?
I look for quality/performance - An option that your questionnaire lacks.
I don't care how it looks or if the price is slightly high,for good quality i am ready to pay extra.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1275861-pc-case-design-project/#findComment-14262881
58 minutes ago, tkitch said:
your question options are pretty terrible, and don't give any granularity to answers, Many of the responses don't really work for many people.
Thanks for the feedback, do you mind being more specific, would appreciate any ways I can improve.
https://linustechtips.com/topic/1275861-pc-case-design-project/#findComment-14263032
By (of a certain performance level) I meant: if all the components had the same performance and quality, would you go for one that is cheaper or better looking or a compromise...
https://linustechtips.com/topic/1275861-pc-case-design-project/#findComment-14263041
