Javascript function calling trouble with newly created element. Help?
EDIT: I just browsed around more and used quiz2input1.onclick=newF1 for it. it works!!
Hi. I have a huge project due tonight and this is the last thing tripping me up. I know it's excessively messy and i could simplify it, but I don't have the time
Anyways, the webpage responds to the initial call by pressing a button (id="buttonStart"). It then correctly displays the "Are you 18 or Older" next to the buttons "Yes" and "No". The problem is when I click on the buttons- nothing happens even though I added ".addEventListener()".
First is the HTML that is being manipulated, next is the script I have inserted into the section element above it.
This is a 101-level course so there is much I cannot incorporate. Any help is appreciated!! Google has been thoroughly exhausted.
I've tried most variables in multiple different locations, either in or out of the code. Didn't make a difference.
<article id="p2quiz2"><h3 id="answerTo">Can You Have Ice Cream?</h3>
<div><p id="quizDialog">Click the Button to Start the Quiz!</p>
</div>
<input type="button" id="buttonStart" value="Click to Start" onclick="leavePlease();doiNeedThis1();doiNeedThis2();"><br><br></article>
<script>
var buttonRemove= document.getElementById("buttonStart");
var quiz2input1=document.createElement("INPUT");
var quiz2input2=document.createElement("INPUT");
var txt1=document.createTextNode("Yes");
var txt2=document.createTextNode("No");
function leavePlease(){
buttonRemove.remove();
document.getElementById("quizDialog").innerHTML="Are You 18 or Older?";}
function doiNeedThis1(){
quiz2input1.appendChild(txt1);
quiz2input1.setAttribute("type","button");
quiz2input1.setAttribute("value","Yes");
quiz2input1.setAttribute("id","yesA");
var dialogIDvar=document.getElementById("quizDialog");
dialogIDvar.appendChild(quiz2input1);
function doiNeedThis2(){
quiz2input2.appendChild(txt2);
quiz2input2.setAttribute("type","button");
quiz2input2.setAttribute("value","No");
quiz2input2.setAttribute("id","noA");
dialogIDvar.appendChild(quiz2input2);
document.getElementById("noA").addEventListener("click",newF2);
document.getElementById("yesA").addEventListener("click",newF1);
function newF1(){
var moreRemove1= document.getElementById("yesA");
var moreRemove2= document.getElementById("noA");
moreRemove1.remove();
moreRemove2.remove();
document.getElementById("answerTo").innerHTML="You Can!";
function newF2(){
var todayDate=new Date();
if(todayDate.getDay() == 6 || todayDate.getDay() === 0){
document.getElementById("answerTo").innerHTML="You Can! It is the weekend.";
else{
document.getElementById("answerTo").innerHTML="You Cannot. It is not the weekend.";
</script>
another function i have trouble with is this but it's MUCH less urgent. It does not respond at all. Yes it is asking if the user loves my dog. I'm exhausted.
<article id="p2quiz1">
<h3 id="doyouLike">Do You Like Nicky?</h3>
<p><img src="nickycsce.PNG" width="510" height="370" alt="Nicky2"></p>
<form>
<input type="radio" id="NickyYes" name="Opinion" value="Yes">
<label for="NickyYes">Yes</label><br>
<input type="radio" id="NickyAbs" name="Opinion" value="Absolutely">
<label for="NickyAbs">Absolutely</label><br>
<input type="button" value="Finished" onclick="goodChoice()">
<script>
var yesS= document.getElementById("NickyYes");
var absS= document.getElementById("NickyAbs");
function goodChoice(){
if(yesS.checked= true;){
document.getElementById("dpyouLike").innerHTML="You could have been more Enthusiastic"
else if (absS.checked = true){
document.getElementById("doyouLike").innerHTML="Good Choice."
else{
document.getElementById("doyouLike").innerHTML="wtf";
</script>
</form>
</article>
