3070 does not work properly
Go to solution Solved by FlamingNirvana,
the problem was in my cpu  it was in cenebench  3700 on multi  and  it was running very hot   i was about to change the stock cooler  and that when i noticed  that i haven't locked the cooler the way it should  after doing that. now i have  9000 on. enebench  x.m.p on
soo. i got my hands on msi 3070 ventus 3x
and when i play games with it wont pass 80-100 fps on high settings 1440p or 100-140  fps on extremely  low 1440p  on fortnite, modren warfare.
cpu usage below 40%
ram usage below 60%
gpu usage below 20%
i concted the nvidia live chat for help but they told my i have a bottleneck  qnd i need to upgrade  i have  b450 and r7 2700x  and 750w
i would like if someone  can help me though discord  or teamviwor or something  my discord  is : Flaming Nirvana#0016
https://linustechtips.com/topic/1275221-3070-does-not-work-properly/
Just a quick question what is your percentage of cpu usage while playing games/running a benchmark. If its 100% it means you're cpu limited and need and upgrade in that department.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
cpu usage below 40%
ram usage below 60%
gpu usage below 20%
Did you try and ddu the driver and install the latest one if you don't know how to do it google it.
AMD blackout rig
Just now, FlamingNirvana said:
i did downgrade  the gpu driver but it did not fix it
well try and ddu it and install the latest ones its the most common issues with graphics cards.
AMD blackout rig
still the same thing.   if you  can  join me in a TeamViewer or something it would be great
look am kind of noob in this area hahah but i did  call l the Nvidia support and i did with them these steps                                                          1 downgrading using DDU
2 reinstall GPU to a different slot
3 reinstalled OS
4 did a stability test for an hour
5 change the power usage from the NVidia panel to maximum performance and enabled debug mode
6 updated bios
38 minutes ago, LordVetinari said:
What's the refresh rate of your monitor?
Could you try a timespy run?
Graphics score
13 388
CPU score
3 578
Time Spy Score
9 486
Good
AMD Ryzen 7 2700X Eight-Core Processor
NVIDIA GeForce RTX 3070
Your score
9 486
Average
12 451
Best
14 393
12 minutes ago, FlamingNirvana said:
Graphics score
13 388
CPU score
3 578
Time Spy Score
9 486
Good
Your score
9 486
Average
12 451
Best
14 393
I picked up the exact same card a couple of days ago as well and just ran time spy to double check, I got a graphics score of 13501 so yours sounds about right.
My CPU score is 7559 on a mildly OC 3600xt though. I would have thought the 2700 would have been closer to this....
1 hour ago, FlamingNirvana said:
i did  Shadow of the Tomb Raider benchmark on highest +raytracing  on 1440p i got on average  of
41fps
I just ran it the same at 1440p with every setting cranked + ray tracing and my average was 69fps.
Without ray tracing I got way higher - 106fps.
Guru3d has a CPU score in timespy for the 2700x of 9428.... Are all your cores on and hyperthreading  enabled?
well the. SMT MODE  is on auto  soo i think it's enabled
What game specifically are you experiencing these framerates on?
Edit: nm, fortnite and mw
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
