Case fan config
Go to solution Solved by Zonal,
11 minutes ago, Bartandroid123 said:
My case is the pure base 500
Im planning to put a 240mm aio on the top but as intake will it be okay
my current case fan config:
2 140mm front intake
1 140mm top exhaust
1 140m back exhaust
Why would you have top being intake? All the hot air would just be going back into your pc. Make it exhaust. I’m pretty sure that case can have a 240mm aio.
1 140mm top exhaust
1 140m back exhaust
https://linustechtips.com/topic/1275106-case-fan-config/#findComment-14257150
