I just got the asus vg248qe monitor and i cant seem to get the hz past 60 this monitior max is 144hz witht he dual link dvi cable but i cant use that since i have it connected to my laptop witch is the asus g75vw. i just want to get to 120hz since i wont be able to connect through the dual link dvi to get the 3D/144hz. Any ideas would be great
https://linustechtips.com/topic/12751-refresh-rate-issues/
HDMI version used in your laptop OR the HDMI cable used doesn't support more than 1080p at 60Hz, is what it looks like.
If it's not the cable, ASUS probably used an old version of HDMI, due to the high royalty cost needed for the latest and greatest version of HDMI. This is common thing. And even then, I RARELY ever saw HDMI on either desktop graphic card and laptop, actually work well like DVI or DisplayPort. HDMI was not designed for computer it was designed for home entertainment (TV's, Blu-ray, etc. is what I mean).
I recommend to people to always looks for DisplayPort on a laptop (or dual link DVI if you can have that, but that's very rare). DisplayPort works perfectly like DVI. It's only downside is if you need to drop DisplayPort down to dual link DVI, then you need an expensive adapter/converter, but single link DVI (1920x1200 @ 60Hz max) then just an inexpensive adapter one is all you need. Today, more and more monitors have DisplayPort, so I don't think its much an issue.
https://linustechtips.com/topic/12751-refresh-rate-issues/#findComment-136619
You could try to set this as a custom resolution: 1280x720@120hz.
I don't know how to do it on an nvidia card, but I think it is easy, you'll have to google it, it is a simmilar process as downsampling, just set it to the res and refresh rate I wrote before. HDMI should be capable of 720p@120hz, can't guarantee anything tho. Also, don't worry about 144hz, i have a 144hz monitor and there is not a noticable difference between 120hz and 144hz ;)
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/12751-refresh-rate-issues/#findComment-137691
  • 2 weeks later...
If the monitor has DisplayPort, then yes.
But if the monitor does not, and you'll use a converter down to DVI, you'll only get single link DVI. Which means that you have at best 1920x1200 @ 60Hz.
You need an active powered DisplayPort to Dual Link DVI adapter. Those are costly, and I have no idea if the adapter support 120Hz+, as you have a circuit inside.
https://linustechtips.com/topic/12751-refresh-rate-issues/#findComment-196196
Try the Display Port as GoodBytes said. HDMI can't handle the bandwidth that anything above 1920x1080/60Hz produces. If your monitor hasn't got a Display Port input, then your only hope is an adapter, but I'll warn you now - I've found them to be extortionate in price.
My setup used to be linked here but links aren't allowed so... it shall remain a mystery!
https://linustechtips.com/topic/12751-refresh-rate-issues/#findComment-196231
