monitor detection
Solved by patken007,
I’ve just booted up my new PC for the first time, so far so good. no explosion But only downside, I have no display. Yeah, I did check all cable and port and yes my monitor is connected to a power source.
Am not sure if the backplate might be interfering with my cable just a bit. But I do hear a click when I connect it. I’ve tried all the display, and HDMI also. But so far nothing.
My GPU is a Asus Strix 3080
ANY SUGGESTION??
