Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
hey guys i was wondering if pc cases come eith standoff screws or motherboarda im so confused l
https://linustechtips.com/topic/1274747-pc-i-need-help/
Usually case has all the standoffs. Some higher end motherboards come with couple standoffs aswell.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1274747-pc-i-need-help/#findComment-14254370
Country:
Your case usually will have all the standoffs installed for all the motherboard sizes it can support. If they aren't installed in the case, they'll be in a bag of hardware that will be included with the case.
https://linustechtips.com/topic/1274747-pc-i-need-help/#findComment-14254393
