Hey Guys! I currently have this Pump Reservoir Combo from Thermaltake. Thermaltake Pump-Reservoir Link . Attached is my PC, I would like to shorten the Reservoir so that I will be able to move my Radiator to the top and not the front.
If you guys can provide a link to amazon it would be great
Please let me know!
Thanks Guys
https://linustechtips.com/topic/1274447-help-for-pump-reservoir/
Hi buddy, since in most use case scenarios, reservoir capacity doesn't affect cooling capacity, you could try either the 100 or 120 versions of EK's Quantum Kinetic TBE pump / res combos.
From the looks of it, it should fit straight into where your existing unit sits but take up much less vertical space.
EK has detailed dimension in their product data sheets so you can check each unit to see the sizes.
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
