Budget (including currency): 830 euros
Country: Greece
Games, programs or workloads that it will be used for: 3DSMAX ,lumion  and other workstation  things
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): We already have : an ssd , Ram , and psu
So i want some help woth this build , and my  main question is , do i choose the 5700xt or 2070 ?
Also , i just a discount from a local shop , a 2700x for 200 bucks , is it worth?
https://linustechtips.com/topic/1274311-a-build-for-next-week/
Honestly, if you are mainly using the build as a workstation, you might consider getting a cheaper gpu and a better CPU instead. Besides that, the new RX 6000 and RTX 3000 series cards will be available at some point, so there is no point in spending tons of money on a 5700xt or 2070.
https://linustechtips.com/topic/1274311-a-build-for-next-week/#findComment-14251271
