Perhaps this thread can help you
CPU: Ryzen 7 3700X @4.3Ghz All-Core with Stock Cooler
Motherboard: Asrock X570 Phantom Gaming 4
RAM: Patriot Viper 32GB DDR4 RAM @3000Mhz
GPU: MSI Ventus RTX 2080 Super 8GB
PSU: Corsair RM750X 80+ Gold Fully Modular
Storage 1: Phison 500 GB NVME SSD
Storage 2: WD Blue 1TB NVME SSD
Case: Inwin 146 ATX Case
Peripherals
Mouse: Logitech G Pro X Superlight
Keyboard: Razer Huntsman Tournament Edition
Headset: Drop x Sennheiser PC38x
Monitor 1: LG 27GL850-B 1440p @144hz Nano-IPS Monitor
Monitor 2: Asus VG248Q 1080p @144hz Gaming Monitor
Monitor 3: Asus VG259Q 1080p @144hz IPS Gaming Monitor
https://linustechtips.com/topic/1273288-i-need-help/#findComment-14243273
21 minutes ago, The General said:
does my Msi A320m pro-e support ryzen 3 3100? or 3rd gen ryzen, im upgrading from an Amd A8 9600 cpu. I have a graphics card gtx 1050 ti. I dont know how to update my BIOS
yes its am 4 socket. check your bios version first then download the bios file. keep it in a usb thats fat 32. unzip the bios file and keep it in the usb main directory. run the bios and look for bios update and navigate to the usb and update
https://linustechtips.com/topic/1273288-i-need-help/#findComment-14243280
oh yeah how do I know my bios version?
https://linustechtips.com/topic/1273288-i-need-help/#findComment-14244439
