Within the last few months I have not been able to get my brand new pc's front audio output or my front mic input to work on my computer.  I have been trying everything I can think of to trouble shoot.  I have checked my drivers. I have restarted numerous times.  I have replaced my entire front io.  I have tried other headsets.  I have even replaced the motherboard.  I have made sure the cords are fully plugged in.  I have routed the audio cable away from the power supply.  However my rear audio ports work perfectly fine.  Any help would be greatly appreciated and I am willing to answer any questions that may help.
https://linustechtips.com/topic/1272790-front-io/
Well I was hoping for some better pics. I can't tell if you are plugged into the audio header or not. What model mobo is this?
And when you say you replaced the front io what exactly does that mean? Can you take a pic of your whole io panel.
https://linustechtips.com/topic/1272790-front-io/#findComment-14241717
