PC Problems
Go to solution Solved by cr8tor,
15 hours ago, Jakubman625 said:
Hello i did not tried to check the RAM But i found BIOS Site with version i have. https://www.gigabyte.com/Motherboard/GA-990XA-UD3-rev-30/support#support-dl-bios Is this the right driver?
Yes looks like it.
I did not realize the version was not correct.
Good job on tracking down the correct bios.
7 hours ago, cr8tor said:
ok, well, there could be something else going on.
Flashing the bios is kind of a multipronged troubleshooting step in that it sometimes fixes things with code updates.
But it also forces the bios to redetect hardware, similarly to clearing the bios like i had you do earlier.
It also can confirm board issues in the fact that if you cant flash a board bios, something is wrong somewhere.
Sometimes its the board, it could be something else though. CPU, memory.
Do you have any peripheral cards in the system that can be removed, or anything plugged in other than the mouse, keyboard and monitor?
If so remove them and try again.
Also, is there an option in bios to restore defaults? If so you might do that and try again.
If not or if it doesnt help, reseat your memory and GPU. Test the system to see if the original problem went away.
If the problem still exists after reseating the memory, reseat the CPU.
Also, i just realized you have 12gb of ram.,
You have mixed size ram modules done you?
Like to 4gb's and two 2gb's?
If so, try two matching sticks at at time.
Make sure you have them in the correct slots, generally slot 2 and 4.
Check your motherboards manual for memory placement if needed.
https://linustechtips.com/topic/1272501-pc-problems/page/2/#findComment-14246486
Yes looks like it.
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
https://linustechtips.com/topic/1272501-pc-problems/page/2/#findComment-14248743
2 minutes ago, Jakubman625 said:
It´s Updated! :) It Did a thing that scared me :D It said it couldn´t find any operating system but after pressing Enter it booted to Windows. Im going to try if it repaired the problem :)
16 minutes ago, cr8tor said:
Yes looks like it.
It WORKS!!! :) Im so happy :) Thank you so much for helping! :) Have a wonderful day :)
https://linustechtips.com/topic/1272501-pc-problems/page/2/#findComment-14248778
18 minutes ago, cr8tor said:
Yes looks like it.
But now every time when its booting it shows me that it could not find any disk with operating system. but after pressing enter it boots to windows. What to do with it?
https://linustechtips.com/topic/1272501-pc-problems/page/2/#findComment-14248791
Pull the USB key out of the system.
Sounds like its trying to boot to it.
Family machines
https://linustechtips.com/topic/1272501-pc-problems/page/2/#findComment-14250459
Hi It Helped but the USB i had in the comupter was a backup USB (With Windows Files) and after the update BIOS made it the first Boot device so i had to change it to the SSD and now it works without any problem :) Thank you so much for your help! :)
https://linustechtips.com/topic/1272501-pc-problems/page/2/#findComment-14250576
Yep, im glad i was able to help.
I figured thats what the issue was.
Glad you figured it out the rest of the way.
Have a long and prosperous life my fellow human.
Family machines
https://linustechtips.com/topic/1272501-pc-problems/page/2/#findComment-14250966
