ok so my gpu fans are vibrating and just making ticking noises its very annoying to me so i would like to fix this quickly
the graphics card is an r9 280x http://www.msi.com/product/vga/R9_280X_GAMING_3G.html#overview
this only begin happening recently and i have no more ideas on how i could fix it.
i have already taken the card out to clean it and check if nothing is on the fans.
i have also tried to adjust the fan profile to se if there is a rage i can use it in without the noise but from 45% to 100% its ticking and making a lot of noise.
thanks in advance
''FX-9590 Hotter than lava''
https://linustechtips.com/topic/127155-graphics-card-fan-vibrating/
You should rma it as the fan vibrating will damage the motor, so best to rma before it breaks completely.
yeh that looks like my only option good thing i can take it back to umart and they will rma it for me at least
There are other options.
