Will my pc build work?
Go to solution Solved by eeeee1,
11 minutes ago, jokeTV said:
budget: 250 to 300 euros
what games i will play: roblox, cities skylines, poly bridge, many more
target res, fps and quality: res is my screen size aka 1280 x 1024, fps target is 30 to 60 fps and quality is low to medium
please remember to quote people so that they are notified when you reply. this can be done either through the image.png.d0bdd597aa208598b20dc99aa8461e04.png button or by doing @jokeTV
what you are upgrading to should work fine i guess.
Country: Latvia
Games, programs or workloads that it will be used for: gaming and doing homework
Other details: heres my pc specs: https://www.userbenchmark.com/UserRun/35186611
Hello ltt community, im gonna upgade my pc soon, i will buy an nvidia 1030 bc my intergraded graphics are bad, intel core duo E8400 3.0 ghz because guys in quora said it will do the job of getting max out of gt 1030, sata 3 card bc my motherboard supports only sata 2, the sata 3 card will let me have full ssd speed, 800 mhz ddr2 4x2 gb ram bc my motherboard only supports ddr2, and possibly an new power supply bc of the upgrade, ltt community, is this pc build gonna work bc im thinking that it will not work also idk how much it will cost im thinking around 250 euros.
https://linustechtips.com/topic/1270776-will-my-pc-build-work/
ok. can we get:
budget
what games will you play
what is your target resolution, frames and quality
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1270776-will-my-pc-build-work/#findComment-14224543
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1270776-will-my-pc-build-work/#findComment-14224598
