Just now, Kyoshin said:
My specs are
GeForce GTX 960M
Intel(R) Core(TM) i5-7300hq CPU 2.50GHz
7.89 GB RAM
and I'm struggling to get above 20 fps on minecraft and decent fps on valorant and I've tried everything.
Any tips?
First, check your laptop temps, and update your GPU drivers. Also check if you have a virus, or if you always have intensive tasks running the backround.
To improve FPS in Minecraft,
-Download optfine
-Play on lower settings
-Put more RAM into the game
Valorant is already pretty optimized, so just try to reinstall the game
If none of that works maybe a reinstall of windows would help
geometry is hard
b550 > x570
https://linustechtips.com/topic/1270604-help/#findComment-14223195
optimization can only go so far. Valorant is no CSGO. with a MOBILE gpu you can only ask so much.
what i would do instead, is lower your settings. turn things down to low or medium. this will lessen the load on your gpu.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1270604-help/#findComment-14223210
that is true, but note that the difference between high and low on valorant is 10 - 20 fps
geometry is hard
b550 > x570
https://linustechtips.com/topic/1270604-help/#findComment-14223241
Overheating might be an issue. Seeing your specs, I suspect it is a very old machine...
I had a Sony Vaio with much older specs:
Intel i5 2430M [ Base 2.7GHz Boost 3.0GHz ]
Geforce 410M
4GB RAM
The fan was clogged with dust which caused thermal throttling. After cleaning it up, It stays 2.9GHz on loads and the GPU also hits the max clocks....
Also I found out that you could overclock the GPU?! Through afterburner, I pushed it until I had glitches, then downclocked a bit, stress tested and voila! Gives around 15% more performance and is stable AF!
https://linustechtips.com/topic/1270604-help/#findComment-14223246
i mean if its the difference between 30-40 to 60 fps....
atleast you hit the what i call "absolute minimum" for a competitive online fps game
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1270604-help/#findComment-14223254
