With good airflow, should be fine.
Keep in mind this case is designed for quietness as a priority, so thermals may run a touch higher.
I have my build in the Design R4 and it was warm until I put the top fans in as exhaust, that made a big difference.
Potato Revamp
CPU: AMD 5900x || GPU: nVidia RTX 3080 || RAM: 32gb Trident Z Neo CL16 || Case: Fractal Torrent Compact || CPU Cooler: Scythe Fuma 2 || PSU: Corsair RM850 Gold || Storage: ADATA SX8200 Pro (1TB), 2x Samsung Evo 870 (2TB)
https://linustechtips.com/topic/1269082-fractal-case/#findComment-14214041
Cooling should be adequate with the stock case fans.
https://linustechtips.com/topic/1269082-fractal-case/#findComment-14227301
Someone please help I'm in the process of transferring my computer over to new and I'm done but the fractal design case come with 3 pin connectors and cannot get them connected into 4 pin headers on Asus b550 f gaming wifi atx board
https://linustechtips.com/topic/1269082-fractal-case/#findComment-14228828
There's a notch to line up the headers.
large?v=1.0&px=999
https://linustechtips.com/topic/1269082-fractal-case/#findComment-14228834
18 minutes ago, woody30 said:
These grooves or slots on topare keeping it from going on connector how do I get past that
Scroll up to my previous post and check out the additional image that shows how the notch lines up with the guides on the fan connector.
If you're trying to plug the fan into cha_fan3, make sure the guides are facing downwards at the psu shroud.
https://linustechtips.com/topic/1269082-fractal-case/#findComment-14228852
Ok I was able to get it and thank you for quick response on my issue now I just to tidy up some cables and plug it into see if it works tomorrow
https://linustechtips.com/topic/1269082-fractal-case/#findComment-14228888
