Hi guys,
Can anyone help me get a VM up and running inside OpenMediaVault 5.5.16-1
I've been watching the Techno Dad Life YouTube vids to get me this far but a lot of his vids refer to OMV ver 4.x and the VirtualBox plugin isn't available on ver 5.
Other vids refer to using Cockpit but as newb, I'm pretty lost.
I have tried creating a VM with Cockpit from a Ubuntu ISO but as soon as I click 'Create' I get the following error:
ERROR Network not found: no network with matching name 'default' Domain installation does not appear to have been successful. If it was, you can restart your domain by running: virsh --connect qemu:///system start Ubuntu otherwise, please restart your installation.
I have also tried installing VirtualBox from the terminal but I didn't get far with that either.
My last resort was to try and remote desktop into OMV and see if I could get Vbox running with a GUI..... Fail! While I did manage to get to a desktop it whinged about not being able to connect to a display.
As a side-note, I am trying to get lancache and pi-hole running on the same box and quickly realised this wasn't possible with out-of-the-box settings but I did manage to do this before by running lancache on the host and pi-hole on a guest and pointing the UPSTREAM_DNS to the pi-hole VM IP.
Any ideas?
Cheers
C
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1268706-vm-inside-omv-5-help/
28 minutes ago, Electronics Wizardy said:
Id really suggest just running a hypervisor like proxmox here, makes running vms much easier.
If you just want to connect to kvm on the host, you can use virt-machine-manager to connect to it from a remote system.
Thanks for the tip however, would you know what's going wrong with OMV?
I only need a single VM up and running and it doesn't even need to be Ubuntu, Raspbian would do the trick so VM management isn't really a high priority.
Thanks
https://linustechtips.com/topic/1268706-vm-inside-omv-5-help/#findComment-14208287
Thanks
since you just want lancache and pi hole, you can just install docker on the omv system and run it from there, don't even need a vm.
OMV isn't made for vms, so thats explains the issues your having here,
how are you remoting in? Is there x running on the system?
https://linustechtips.com/topic/1268706-vm-inside-omv-5-help/#findComment-14209125
I recall trying the pi-hole in a container a while ago and it spat the dummy. I'll try again and report the error but if i recall, it was something to do with the ports. Lancache / Sniproxy used port 80 and 443 so I think there was a conflict.
With regards to remoting in, I followed a vid to install Mate desktop and then used the Windows remote desktop tool. It appeared to work but when I tried to run VirtualBox from the GUI it errored out. I cant remember what the exact error message was but it looked like a display issue.
I'll give pi-hole in docker another bash and see what happens.
https://linustechtips.com/topic/1268706-vm-inside-omv-5-help/#findComment-14210684
