BSOD Internal Power Error
Go to solution Solved by Helpful Tech Witch,
2 minutes ago, MigasTigas said:
Thanks it booted for now, any idea what that is about?
windows bsods randomly on even healthy systems, just post again if it continues.
I have a Asus A541UJ that it's being used as family computer right now.
A family member was going to use it, around 3 hours ago so I turn on while I was doing some work on my main pc. The laptop remain idle all the time (the member after didn't need to use after all) and when the member came to shutdown, he started to shutdown and then bam BSOD'd with the error. It's been "frozen" in this state for 15 mins tops by far.
What is this error (which I never seen this one, and it's not the first time I am welcomed with this blue screen) and how do I fix it?
804159728_WhatsAppImage2020-11-12at23_20_22.thumb.jpeg.da09ede97c6491d29509a63b32d5433b.jpeg
Current Rig:
Mobo - MSI B450 Pro-Max VDH | CPU - Ryzen 5 3600 (AMD duh) | GPU - GTX 1660 Super (MSI) | WAM - 2 x 8GB 3200MHz (G.SKILLS Ripjaws)Storage - 1 x 256GB SSD (Crucial MX500) + 1 x 2TB | HDD 7200RPM (Seagate Barracuda) | PSU - Cooler Master 450W | Case - Cooler Master Q300L | Display - Asus VP248QG (Main) + AOC 24B1W1 | Other Stuff - Bloody B120 (Keyboard) + HP X220 Gaming Mouse + Asus A541UJ (Laptop)
https://linustechtips.com/topic/1268456-bsod-internal-power-error/
just force  it off (hold power for like 5-10 seconds) and it should be fine.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
Current Rig:
Bios database
prior build:
Lol, so it's whines "for nothing", thanks!
Also i'm noticing that after boot is way slower, files are taking way too long to appear in desktop, and the taskbar is unresponsive, so i'm assuming explorer.exe is frozen? This is a HDD but until now was way faster then what is taking now..
Current Rig:
try a reboot.
Bios database
prior build:
2 minutes ago, HelpfulTechWizard said:
try a reboot.
Can't reboot via windows, only by shuting down again...
Current Rig:
then wait a bit. sometimes windows does self chescks after bsods, where taskbar ect doesnt work.
What happens when you press the winows key?
Bios database
prior build:
nothing, it might be just lagging
edit: as soon i published this it worked and all the actions i requested (win key) popped into action
Current Rig:
Quick update: it froze again, now can't open anything again :/
Current Rig:
So after a while managed to reboot, and some idle after decided to shut down and no BSOD now so I'm going to mark your answer as solved! Thank you for the help!
Current Rig:
