Leona system use
Gaming, streaming, editing YouTube videos (cooking tutorial videos), doing her taxes.
Her original rig
CoolerMaster NR400 - (upgraded last year)
Ryzen r7 1700x
CoolerMaster hyper 212 Black (upgraded last year)
Gigabyte GA-AX370m - ds3h(rev1)
Corsair lpx 3200mhz cl14 16gb - 8gb x2 sticks (1st gen)
Crucial m.2 sata ssd 1tb
Western digital black 6tb hdd
Gigabyte GTX 1070ti twin fan
CoolerMaster MWE gold 550W 550w 80+ gold
System update.
CoolerMaster NR400 - reuse
Ryzen r5 5600x or ryzen r7 5800x
CoolerMaster hyper 212 Black - reuse
Asus tuf gaming b550m ax
G.skill trident z neo rgb 3200mhz cl15 32gb 16gb x 2 sticks
Crucial m.2 sata ssd 1tb - reuse
Western digital black 6tb hdd - reuse
Rtx 3070 or rx 6800 - undecided
CoolerMaster MWE gold 850w 80+ gold - (upgrade)
Question : she's wondering can the 5600x handle her workload, or does she have to spend the extra on an 5800x ?
She's on a quite tight budget.
Silent Cerberus - Fractal Design Core500,Ryzen R7 3700x,Scythe Fuma 2,Gigabyte Aorus B550i Pro AX,Crucial Ballistix Elite 3200mhz cl16 16gb,Adata XPG SX8200 nvme 512gb m.2 ssd,Lexar NS100 1tb ssd,Red Dragon RX5700 8gb(bio flashed 5700xt),Corsair SF600 SFX 600w 80+ platinum F-Modular.
Hades - dO.Ob Look into my eyes and see the dark eternal abyss that is your soul and pay for your hidden sins.
Cerberus - the hell hound that guards the gates of hell. Once you enter you'll never escape.
https://linustechtips.com/topic/1267847-system-upgrade-classmate-steaming-system/
2 minutes ago, StrawberryShortCakes said:
Leona system use
Her original rig
Ryzen r7 1700x
System update.
The 5600x isn't great for editing, but it will get the job done, and its significantly better than the 1700x she already has. Also, try to get faster RAM (3600mhz CL16). Other than that it looks ok, but if you want to upgrade later down the line you would need a new CPU cooler
geometry is hard
b550 > x570
If she's on a tight budget, the 5600X will work fine, and is stil an upgrade over a 1700X in rendering and encoding workloads.
Source: https://www.anandtech.com/show/16214/amd-zen-3-ryzen-deep-dive-review-5950x-5900x-5800x-and-5700x-tested/15
Notes: Zen 3 currently benefits significantly from Quad-DIMM configurations. It is my reccomendation to buy a 2nd set of 8 GB 3200 CL14 DIMM's, and run it together with the older memory.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
Those cl 14s she got were from a lucky draw, you can't find cl 14s cheap in Singapore.
They are expensive as ****.
I'll get her a quad set of cl15s.
13 minutes ago, boggy77 said:
with a tight budget, go for the 3700x, so that she doesn't have to change motherboard too.
Either way she needs to change the mb it's bios can't be updated the rev 1 version won't allow the bios update for 3000 series it's dead in the water. I checked with gigabyte.
