Budget (including currency): $1500 (without counting monitor and peripherals)
Country: USA
Games, programs or workloads that it will be used for: Just mainstream games, and I will use this for school work etc in the future, nothing too intensive, but I want this to last for a while
So pcpartpicker is saying that there needs to be a bios update, even though I have a 5600x and a B550 series mobo, which doesn't really make sense. Also, any thoughts on waiting for the 5600 (no x)? Will that bottleneck the rtx 3070? Another question I had was about the aRGB fans that I have. They come with a controller, is that independent of the mobo? And if I wanted to use the motherboard software, I think I would have to daisy chain them, so could someone explain that process simply? Additionally, I am a first time builder, so I am probably gonna stick with the air cooler, but if anyone has a good recommendation (aRGB would be nice) for a similar price, please drop it below! Here is my list for other comments.
https://linustechtips.com/topic/1267120-pc-build-help/
Consensus is that no such CPU is going to come out.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/1267120-pc-build-help/#findComment-14194750
Check this part list.
PCPartPicker Part List: https://pcpartpicker.com/list/YWXJMv
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($299.99)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($89.90 @ Amazon)
Motherboard: MSI MAG B550M MORTAR WIFI Micro ATX AM4 Motherboard  ($169.99 @ Amazon)
Memory: G.Skill Flare X Series 16 GB (2 x 8 GB) DDR4-3200 CL14 Memory  ($99.99 @ Newegg)
Storage: ADATA XPG SX8200 Pro 2 TB M.2-2280 NVME Solid State Drive  ($249.99 @ Adorama)
Video Card: Asus GeForce RTX 3070 8 GB STRIX GAMING Video Card
Case: Lian Li Lancool II Mesh ATX Mid Tower Case  ($137.74 @ Amazon)
Power Supply: Corsair RMi 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Case Fan: upHere T7SYC7 120 mm Fans 6-Pack  ($46.99 @ Amazon)
Monitor: Gigabyte G27QC 27.0" 2560x1440 165 Hz Monitor  ($284.98 @ B&H)
Keyboard: Redragon S113 RGB Wired Gaming Keyboard With Optical Mouse  ($38.99 @ Amazon)
Total: $1418.56
Zen 3 benefits from 4 sticks of ram, you can buy 2 of those kits, 3200 CL14 is the sweet spot for gaming
Better cpu cooler, Asus strix is the best 3070 you can get,
Adata xpg sx8200 pro is faster than a western digital blue and pretty cheap
I would suggest getting the lancool II Mesh but you can also get the meshify c
https://linustechtips.com/topic/1267120-pc-build-help/#findComment-14194785
B550 chipset predates Zen 3 cpu. No worries about updating BIOS. In the event that BIOS needs to be updated use the motherboard Flash BIOS feature. You will need a USB stick and another machine to use the feature.
https://linustechtips.com/topic/1267120-pc-build-help/#findComment-14194793
Total: $1418.56
I do like this build, but sadly it doesn’t fit my budget, you forgot to set a price for the 3070 😭😭.
https://linustechtips.com/topic/1267120-pc-build-help/#findComment-14195090
