I am having the gigabyte z170 k3 gaming mobo and i3-6100, msi r9 390 , 1tb baracuda hdd , corsair lpx 8gb 2133mhz ,gigabyte 650w 80+bronze
My question is : is it possible to add 16gb of ram more? i would go with corsair lpx 2400mhz would be this some problem ? Or i need to change the 8gb as well ? And stay with 16
Thanks for help
Gr
Radza266
https://linustechtips.com/topic/1266264-small-question-to-pro-ppl/
yeah you can add 16 more, but I recommend only 8GB more. 24GB is more than one would need for gaming.
you can use the money you saved and sell your i3, then buy an i5-6600
Primary PC:
PSU tier list
How many watts do I need?
Thanks ... :)yeah i wana upgrade it after new year was thinking about i5-7600k or i7 7700k
the K CPUs, especially the 7th gen CPUs, are overpriced. If you're buying a nice expensive CPU upgrade, I recommend selling your motherboard as well and getting a Ryzen CPU.
For example, the cheapest 7600K on eBay right now is about $160 USD, while the Ryzen 3 3100 new is $110 or so and a decent B450 board is around $70. The i5-6600 is usually under $100 and if you bid on one you might even get a better price.
Primary PC:
PSU tier list
Ohh ... thanks for the input that's  some good info :) i will for sure consider your recommendation 😀 i mean cpu and mobo is almost the same price as just cpu from intel ,thast good price thanks a lot xD
Hi sorry for bothering ... just to be sure if i add 16gb(2x8) to 8gb(2x4) existing already in my pc it want cause any crashes or other stuff just cuz of one is 8gb and the other is 16gb ?
most of the time it is completely fine. different capacities in the same motherboard doesn't have any explicit compatibility problems.
Primary PC:
PSU tier list
More info -
If you want a 7700K its around $300 on the used market (you can't buy it new")
And with 300 dollars you could buy a Ryzen 5 3600, and a decent B450 MOBO. The R5 3600 has 2 more cores, and 4 more threads than the 7700k, while having better gaming performance.
Kinda useless info but I just wanted to share this :)
geometry is hard
b550 > x570
4 minutes ago, Downkey said:
More info -
that was the advice I administered earlier in this topic
Primary PC:
PSU tier list
