Hey this is a build for a friend it will be used mostly for LoL and civ 5 but also heavier games such as far cry 3.
GPU - MSI R7870 Hawk
CPU - Intel I5-3570
RAM - Patriot Viper 8gig kit (4Gx2)
HDD - Seagate 1TB Barracuda
Mobo - MSi B75A-G43 B75
Case - Corsair 300R carbide
PSU - Antex HCG-620m
CPU cooler - Coolermaster hyperX TX3
​Is everything compatible and worth it? You I save money anywhere or optimize it better.
Thanks for the help. Will most likely upload pics once the build is done.
https://linustechtips.com/topic/1266-build-for-a-friend/
Go to PC Case gear instead; better range, pricing and support.
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=118812&action=wish_lists
I'm about to build that for $1100.
You don't need an after market CPU cooler as you don't plan to overclock and the CPU comes with one that is designed for the existing clock speed. Keep in mind a copy of Windows is basically another $100.
Otherwise this: http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=125488&action=wish_lists
https://linustechtips.com/topic/1266-build-for-a-friend/#findComment-17293
So I've updated the build...
CPU - i5 3570
Case - Corsair Carbide 300r
GPU - MSI 7870 Hawk
RAM - G.Skill F4 8Gb
Disk Drive - Samsung SH-2222BB sata
HDD - Seagate Barracuda 1TB
PSU - OCZ ModXstream Pro 600W Modular
OS - Windows 7 Home Premuim 64bit
Mobo - Gigabyte GA-H77-D3H-MVP
I'me worried the PSU doesn't have enough wattage for the system...
https://linustechtips.com/topic/1266-build-for-a-friend/#findComment-17358
