https://www.jbhifi.com.au/products/dell-g5-15-15-6-full-hd-144hz-gaming-laptop-i7-rtx-2070
Heyo I have a laptop it gets around 80c gpu and 94-99c cpu while playing games! (Full fans)
I wandered if those were good temps?
https://linustechtips.com/topic/1265725-what-is-safe-temps/
oh yea on fortnite lowest settings 720p wide
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184162
Holy shit no, that CPU is waaaay too hot. It's probably throttling quite a bit.
Edit: oh well it's a laptop... Not much you can do I guess but that would be too hot for my taste. You can try one of those laptop coolers.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184165
Do they work? this is idle: image.png.70f2fa94522964baf7d276eef28258ab.png
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184168
Oh no its not throtling at all 4.3-4.6ghz at 99c
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184169
12 minutes ago, RTX 2070 Max-Q said:
720p wide
Why on such a low resolution with a 2070?
If that is idle i would look into re pasting and cleaning out the laptop.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184182
It low res bc it will over heat
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184200
im 3440x1440 wide normaly
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184205
Its already overheating and throttling bumping the resolution wont do anything. Also try undervolting the cpu.
Is this with a monitor cause your laptop's resolution is 1920x1080 as shown in the link you gave?
Desktop :
Laptop :
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184207
External samsung ultrawide
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184210
Also how do you under vault A cpu not a gpu in msi afterburner?
Edit: and any software
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184211
https://www.ultrabookreview.com/31385-the-throttlestop-guide/
Use this.
Also software is called throttlestop.
Desktop :
Laptop :
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184217
image.png.4e8709db714fbbad0c84a5297db4c6e3.pnguhhh
Yeah thats normal. Click ok.
Desktop :
Laptop :
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184221
Omg dude tysm this is a bit overkill?! but 3440x1440 on fnite gets 56c cpu 50c gpu
Wdym if its overkill? as long as the system is stable it will be fine. Have fun gaming.
Edit: Mark your question as solved so others can see the solution if they have a similar problem.
Desktop :
Laptop :
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184232
50c at stretched 1440p thats a bit wierd but Ill stick with it
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184236
9 minutes ago, RTX 2070 Max-Q said:
I think Ill be fine with 3.0-3.4ghz? Will I?
That is a bit limiting i would try for 3.9 to 4 GHz but that would be fine at 1440p.
If its working then let it be.
Desktop :
Laptop :
https://linustechtips.com/topic/1265725-what-is-safe-temps/#findComment-14184237
