Strange graphical issue.
Solved by WhitetailAni,
5 minutes ago, Maury Sells Wigs said:This is a really strange visual anomaly and the only way I can describe it is if you remember the old cathode ray televisions from decades ago, when there was interference and the signal wasn't very strong, you would get this sort of snowy effect made up of pixels which had a kind of fuzziness to it.
It isn't that bad, but it has that same kind of sparkly pixely quality.
Your monitor had a CRT boyfriend/girlfriend that died and is doing that to remember him/her.
