Budget (including currency): TBD
Country: US
Games, programs or workloads that it will be used for: CoD etc.
Looking to see what the best upgrade would be. There is a CPU cooler in there, just do not have the model for that or the power supply handy. I know the power supply is a 500W EVGA. I plan to grab a decent HDD for storage, probably a 2TB.
TIA
https://linustechtips.com/topic/1265271-upgrade-advice/
Honestly it depends on what your mostly doing. If you are gaming i'd recommend going to a 5600XT (around $250).
If your doing video rendering, or just workstation applications, a ryzen 5 3600 would be a good upgrade.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1265271-upgrade-advice/#findComment-14180500
