Budget (including currency): £800
Country: United Kingdom
Games, programs or workloads that it will be used for: Cyberpunk (High End), WOW as other example
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I am looking at upgrading my current rig and I currrently have a ryzen 7 1700x and a GTX 1080. + 16gb of 3200mhz Ram.
I think I want to keep the 1080 because it is still a fairly solid card. When it comes to the Motherboard + Processor I want to stick AMD probably Zen 3.
If someone could mkae some suggestions for what might be best for the following parts:
  • Motherboard
  • Processor
  • Case
  • Cooling
I currently have a 550w Corsair PSU is it worthwhile upgrading it or because the TDP might go down with the new processor is it sufficient.
I already have plenty of storage but I might consider getting an NVME as a boot drive. It is currently on a Crucial SSD.
Many thanks for any help you guys can provide.
https://linustechtips.com/topic/1264497-rig-upgrade-advice/
  • Motherboard
  • Processor
  • Case
  • Cooling
Ryzen 5 5600x ~ $300
B550 Tomahawk MAX ~ $180
Nzxt H510 ~$70
Corsair H100i ~$150
Corsair RMx 650 - $125
£639 (could go with a higher end CPU but I think that the 5600x is great)
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1264497-rig-upgrade-advice/#findComment-14174080
Nzxt H510 ~$70
Corsair H100i ~$150
Wouldn't go 6c/12t for $300.  Tech Deals makes a good argument.  I'd go 3600 for $180-$200.  It's a better balance with the 1080.
Probably keep the motherboard you have and drop it on.  What motherboard are you using?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1264497-rig-upgrade-advice/#findComment-14174276
B350 PC mate. I am looking at upgrading the board for future proofing and also budget is not the main concern so I am happy to spend a bit more if it gets me an extra year or two so I would consider the upgrade to the 5800x. Rather than go Zen 2.
https://linustechtips.com/topic/1264497-rig-upgrade-advice/#findComment-14174287
exactly. B350 is still supported (i think) but the upgraded speeds will be noticed on B550
Also Zen 3 is insane, so I understand the temptation to go for it, as I would too if I were in need of an upgrade.
https://linustechtips.com/topic/1264497-rig-upgrade-advice/#findComment-14174428
