Laptops don't generally have WAN ports, only modem.
What you're looking at is likely a normal ethernet port, if it was indeed a WAN port then you would only be able to connect it directly to the phone cable that a modem would usually be connected to.
If I'm not mistaken the two are not physically compatible.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/1264233-ethernet-with-wan/#findComment-14172098
Can I use thunder bolt for ethernet? or can I buy an adapter?
https://linustechtips.com/topic/1264233-ethernet-with-wan/#findComment-14172104
1 hour ago, RTX 2070 Max-Q said:
Heyo, my laptop has a wan port I was wandering if I could use wan to ethernet so I can have ethernet!
Thanks
Can you show us the port. Wan is a function not a type of port. It's likely that the port is RJ45 ethernet. What is the model of laptop and what exactly are you trying to do?
https://linustechtips.com/topic/1264233-ethernet-with-wan/#findComment-14172160
Just now, RTX 2070 Max-Q said:
Im trying to connect ethernet.. so I can have wired connections
https://linustechtips.com/topic/1264233-ethernet-with-wan/#findComment-14172187
Low quality but is this a ethernet cableGOPR1084.thumb.JPG.1c6fb02e255fc9b184236f8a898c10e9.JPGGOPR1083.thumb.JPG.30cbfc24d67795b2512a63d7e9804452.JPG
10 minutes ago, Chionele said:
That's a regular Ethernet port, you just need to open it up completely to be able to plug the cable in. Laptops nowadays have these collapsing port designs.
https://linustechtips.com/topic/1264233-ethernet-with-wan/#findComment-14172318
