Recently my gpu has been having artifacts, but when I do a clean reinstall off windows its fine but after the new driver install and a restart it started to have artifacts. I opened up device manger and windows stopped my gpu cause it ran into some issues. I've tried a previous version nothing. However I did get a Bsod code nvlddmkm.sys. I don't know what to do no more I have been having this issue for a while I miss my pc please help.
https://linustechtips.com/topic/1263943-help-i-have-artifacts/
What GPU? Sounds like your GPU is defective.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1263943-help-i-have-artifacts/#findComment-14169610
1 minute ago, Adam Shadow said:
rtx 2070 super
Most likely cause is a bad GPU. I would open an RMA with the manufacture. It should still be under warranty.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1263943-help-i-have-artifacts/#findComment-14169617
