Linux, OG Wraith Spire LED control?
Has anybody found a way to change the stock 1st gen Ryzen's cooler LED colours? OpenRGB doesn't support it and web results don't result in anything meaningful. Also tried running ASUS RGB utility thing under wine, to no avail.
Manjaro Linux | R1700 (3.4GHz) | GTX 1060 + GTX 960 | 3200MHz 16GB
Should be controlled by your motherboards rgb controller.
What motherboard do you have?
What kernel are you on?
