Hi all. I'm planning on building a PC and so far this is the layout I've got configured. I just wanted to verify from someone else on the forum who knows more than me, whether all these parts together will be compatible with one another, and won's create any specific problem. Given the current situation I don't want to be purchasing parts and returning them finding out they aren't compatible with one another. Other links and tips for cheaper/better parts would also be appreciated (Cost is measured in AUD).
Component
Brand & Type
Cost
Web Link
Motherboard
Asus Prime H310M-K
$89
https://www.centrecom.com.au/asus-prime-h310m-k-r20-intel-matx-motherboard
Ram
Corsair Vengeance LPX 16GB (2x8GB) DDR4 3200MHz
$109
https://www.centrecom.com.au/corsair-vengeance-lpx-3200mhz-ddr4-ram-cmk16gx4m2b3200c16
CPU
Intel i5 9400F
$218
https://www.centrecom.com.au/intel-core-i5-9400f-29ghz-41ghz-turbo-cpu
GPU
GTX 1650 Super
$285
https://www.centrecom.com.au/galax-geforce-gtx-1650-super-ex-1-click-oc-graphics-card
PSU
Thermaltake Litepower Gen 2 550W
$69
https://www.centrecom.com.au/thermaltake-litepower-gen-2-550w-power-supply
SSD
Crucial MX500 500gb SSD
$79
https://www.amazon.com.au/Crucial-2-5-inch-Adapter-Internal-CT500MX500SSD1/dp/B0786QNS9B/ref=sr_1_2?dchild=1&keywords=500gb+ssd&qid=1603675018&sr=8-2
Case
Cougar MX-330-S
$80
https://www.pccasegear.com/products/50040/cougar-mx330-s-mid-tower-case-black
Cooling
Hyper 212 Evo 120mm
$80
https://www.amazon.com.au/Hyper-212-Evo-Bracket-Available/dp/B005O65JXI/ref=sr_1_15?keywords=cpu+cooler&qid=1589600274&sr=8-15
Wi-Fi Card
Asus Wi-Fi Card
$18
OFFICEWORKS
Windows 10 Key
Windows 10 Activation Key
$10
https://www.ebay.com.au/itm/GENUINE-WINDOWS-10-PRO-PROFESSIONAL-KEY-LICENSE-Guaranteed-Activation/313087148941?hash=item48e572c38d:g:GCkAAOSw-0Vew17A
Monitor
AOC C24G2 165hz
$290
https://www.centrecom.com.au/aoc-c24g2-236-165hz-curved-gaming-monitor?gclid=Cj0KCQjwxNT8BRD9ARIsAJ8S5xa3VJvimtoLZINn79LYMSPgHcgrHeOXjZG93_wAP9JFaxGXuN7JLmMaAh_xEALw_wcB
Keyboard
Kogan TKL Rainbow Keyboard
$45
https://www.kogan.com/au/buy/kogan-tkl-rainbow-rgb-mechanical-keyboard-brown-switch/?utm_source=google&utm_medium=product_listing_ads&gclid=CjwKCAjwh472BRAGEiwAvHVfGox3f411XUDG7wcwn2Ni8AG4NFVhAYANUtyCLoyQL31EIsLF--pTTRoC7kgQAvD_BwE
Mouse
Razer Death Adder Essential (Black)
$47
https://www.amazon.com.au/Razer-DeathAdder-Essential-Gaming-Mouse/dp/B07Y693ND1/ref=sxin_7_ac_d_rm?ac_md=0-0-cmF6ZXIgZGVhdGhhZGRlciBlc3NlbnRpYWw%3D-ac_d_rm&crid=2JHLOZYPS164B&cv_ct_cx=razer+deathadder+essential&dchild=1&keywords=razer+deathadder+essential&pd_rd_i=B07Y693ND1&pd_rd_r=c0581d9c-fe58-4ca8-8089-e55fab09e5ee&pd_rd_w=PfqnB&pd_rd_wg=D8FdO&pf_rd_p=165462b8-b004-445b-8c70-cf9e9e805494&pf_rd_r=F9RD42DA59CGM39VQFGC&psc=1&qid=1589875553&sprefix=razer+deathadder+%2Caps%2C436&sr=1-1-12d4272d-8adb-4121-8624-135149aa9081
Desk Mouse Pad
Amazer-T Mousepad
$15
https://www.amazon.com.au/Extended-Stitched-Amazer-T-Premium-Textured-Waterproof/dp/B07X7RGD6L/ref=sr_1_1?dchild=1&keywords=cloth%2Bextended%2Bmouse%2Bmad&qid=1603676616&sr=8-1&th=1
Wrist Cushions
VicTsing Mouse/Keyboard Pads
$17
https://www.amazon.com.au/Keyboard-VicTsing-Support-Ergonomic-Computer/dp/B07FR57PWH/ref=sr_1_1?dchild=1&keywords=keyboard+wrist+wrest&qid=1603676875&sr=8-1
TOTAL WITHOUT PERIPHERALS: $644, TOTAL WITH PERIPHERALS: $1068, PERIPHERALS ONLY: $424
https://linustechtips.com/topic/1263211-some-verification-and-help/
Why intel? That mobo won't support your Ram at max speed and probs not your CPU
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
On 10/30/2020 at 11:21 PM, boggy77 said:
if you want intel, at least get the newer generation. a i3-10100 should be as good as that 9400f, but cheaper.
Hoping to probably upgrade to the 10th gen if it drops to a low price. Other than that does my system have any real problems E.G Compatibility issues?
No real incompatibilities. The pau is quite bad and the cpu cooler overpriced for what it can do.
