Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
Hi, ive built a list for my build. Are there any problems with this. i dont want to change anything. i just want to know if its ok. thanks in advance
https://uk.pcpartpicker.com/list/4JJV7X
https://linustechtips.com/topic/1262618-new-build-help/
3 minutes ago, boggy77 said:
wow thank you
i will consider this to my list.  Also,
20 minutes ago, Agena_ said:
Asus ROG STRIX B450-F GAMING ATX AM4 Motherboard
is this motherboard a good option. as i was told by someone that this is not a good motherboard. is this true?
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158125
13 minutes ago, Agena_ said:
wow thank you
that is true, the b450 boards from asus aren't great. however, the asus b550 tuf that I recommended in my build is excellent
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158156
11 minutes ago, Agena_ said:
oh right, do you know why they arent great. im not going to overclock or anything
they have bad power delivery that isn't sufficient to power anything more than a 65W cpu and that will overheat. even if you don't overclock, it will limit the cpus boost potential, so even at stock you might get less performance than with a better board.
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158185
what about this https://www.amazon.co.uk/ASUS-ROG-Strix-Gaming-Motherboard/dp/B08F9VP2RC/ref=asc_df_B08F9VP2RC/?tag=googshopuk-21&linkCode=df0&hvadid=463168706581&hvpos=&hvnetw=g&hvrand=12281372500662358162&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046071&hvtargid=pla-1143333916952&psc=1&th=1&psc=1
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158241
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158268
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158285
6 minutes ago, Agena_ said:
this one is decent, but I really recommend getting a b550 board, why do you insist with the b450 boards?
you can also look for the in the Motherboard tier list (AMD) . i'd go for Tier C or above.
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158325
its mainly the aesthetics. i liked the look of this board. is b450 not good on all of them?
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158329
go with this one then:
https://uk.pcpartpicker.com/product/nFhmP6/asrock-b550m-steel-legend-micro-atx-am4-motherboard-b550m-steel-legend
https://linustechtips.com/topic/1262618-new-build-help/#findComment-14158341
