10 minutes ago, Johnnyyyyyy said:
I was trying to put my hyper t20 in my am3+ mobo and it needed a lot of preasure and I broke my cpu. The clips was too high from the mobo
Well it's too late now for help I think if you broke your system already. What clips are you using? The newer t20 comes with a am4 mount as  the standard not the am3 one so you need to make sure you have the right mount on it.
https://linustechtips.com/topic/1262599-help-with-hyper-t20/#findComment-14157949
I am using an fx 6100 which I have to use an am3+. no post now tho
https://linustechtips.com/topic/1262599-help-with-hyper-t20/#findComment-14158052
Just now, narrdarr said:
They can be pretty tough I think I have cut myself every time Ive used that type of mounting hardware.
 do you have a speaker connected to the motherboard that gives beeps when you turn it on?
it does have a speaker but right now it doesnt beep. but fan headers work
https://linustechtips.com/topic/1262599-help-with-hyper-t20/#findComment-14158073
the problem is i put too much pressure, it did click however it killed may cpu (i think)
https://linustechtips.com/topic/1262599-help-with-hyper-t20/#findComment-14158074
