Dram light and display issues
Solved by cr8tor,
3 hours ago, _Nessquick_ said:Ram slot 1-3:G-skill trident X 2400 ddr3 8gb sticks
Ram slot 2-4:hynix semiconductor 1600mhz ddr3 8gb sticks.
You are mixing memory speeds. Every time you change the memory around, you should clear the bios so it will redetect the memory.
Also, put the gskill memory in the yellow slots and the hynix in the black slots.
Clear the bios by unplugging the PSU, pulling the coin battery and pressing the power button for 5 seconds.
