4 minutes ago, Sam F said:
I have a ryzen 7 3800xt and the temps are spiking between 51-65. is that normal?
A bit more information would be nice. Is this at idle? At load? Is it overclocked? What cooler are you using? What is the cooling configuration of your case like?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1262055-cpu-temps/#findComment-14153364
The answer is yes. On auto frequency is adjusting all the time an thus also voltage and temperature. On Ryzen, even more than before.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1262055-cpu-temps/#findComment-14153375
All auto at idle. I am using a Corsair H100i platinum.
https://linustechtips.com/topic/1262055-cpu-temps/#findComment-14153394
mine idles at 38-50c with a hyper 212 black edition and a very good airflow case. mine is also overclocked albe its at 1.35v so not very high. i suggest you take a look if your room temperature is okay. and if your cpu is indeed seeing high voltage spikes. mine did too at stock. i highly suggest overclocking it. even to something like i overclocked mine to on all cores which is 4.5 it can go higher of course but my cooling is worse than yours. keep that in mind.
just set 4.5 all core on 1.35v in the bios. boot up and see the temps. if they are simular or better than mine then you know that it was just the high voltages
PC:
MSI MPG X870E CARBON WIFI                            (motherboard)  |    Powercolor RX 9070XT Red Devil    (Gpu)
ryzen 7 9800X3D        (cpu)   |   2560x1440 165hz (phillips 27m1c5500v)    (Monitor)
ARCTIC Liquid Freezer III Pro A-RGB 420                (cpu cooler)  |  seasonic focus plus gold 850w      (Psu)
Lian Li O11 Dynamic EVO XL                                         (PCcase)    |  Kingston FURY Beast RGB 32 GB (2 x 16 GB) DDR5-6000 CL30   (Memory)
Steel series apex pro                                                  (keyboard)   |   Razer Basilisk v3 pro    (mouse)
https://pcpartpicker.com/user/hollyh888/saved/LX2cYJ
https://linustechtips.com/topic/1262055-cpu-temps/#findComment-14154915
I do experience voltage spikes from .93v to 1.4
https://linustechtips.com/topic/1262055-cpu-temps/#findComment-14161922
I have tried overclocking but I only have an option in bios to add voltage but I dont know what the stock voltage is. I have a b450 Aorus pro wifi. It also only allows me to add up to 0.3 volts which may not be enough if I running 4.5 at 1.35. Any ideas ?
https://linustechtips.com/topic/1262055-cpu-temps/#findComment-14161929
well apparently people have said that ocing ryzen 3000 at 1.35 or even anything above 1.3 is bad. 🤷‍♂️
and you have to do an manual or overrite mode. that lets you do it. yours should be able to do 4.3 at 1.2v no problem try that :) that really cuts down the temps and well still doesnt destroy your performance completely.
but to reply to your message i have mine running with pbo now. with basically its limits set to the max and it is idling around 49-55c so yeah with a shitty cooler just like mine it is normal.
while having it on the 4.3 at 1.2v it idles around 35-40c so thats better ofc. i may update my cooler after all but that would be around the summer when its 28c ambient temp and not 16-19c orso :D
PC:
https://linustechtips.com/topic/1262055-cpu-temps/#findComment-14171374
