16 minutes ago, oclawson said:
tomahawk b550
ryzen 5 3600
corsair 16gb ram
5700 xt asus
650 watt
6 pack uphere fan pmw
how do I change the fan colors from mother board i downloaded mytic dragon and asus aura but my fna sdont pop up cant seem to find it
Your motherboard should have a RGB header to be able to change the color and stuff. Or you can get a RGB controller or fan hub as they come with a remote to change the lights.
https://linustechtips.com/topic/1261765-fan-colors/#findComment-14150925
Those fans are 6-pin I doubt he will be able to connect them to his mobo.
Uphere tips:
  • The uphere controller and the fan must be used together.
  • please do not use our rgb controller to connect other brands of RGB fan.
  • please do not use our fans to access other brands of RGB controller.
In the future if you are buying RGB fans or anything else RGB you want to connect to your motherboard make sure they have a sticker that looks like these (note the three logo stickers at the bottom).
https://linustechtips.com/topic/1261765-fan-colors/#findComment-14150932
