Crashes during windows install. Farthest I've gotten is the pin/password setup. It will flash black flash back to the original screen then show the Asus screen and not post until I turn it on again, then switch back to windows eufi and choose my flash drive as my #1 boot device, then it happens again.
Ryzen 3 3100
Rx 570 8gb
Pny 240gb ssd
Asus prime a520mk
Ask away please help I've spent 600 and I am desperate.
https://linustechtips.com/topic/1261319-please-help-me/
Probably a corrupt installer, re-make your flash drive with the official windows tool, instructions can be found at https://support.microsoft.com/en-us/windows/create-installation-media-for-windows-99a58364-8c02-206f-aa6f-40c3b507420d
CPU: AMD Ryzen 9 5950x
Motherboard: Asus ROG Strix x570-f Gaming
RAM: Adata XPG DDR4 D60G 64GB (16*4) 3600MHZ RAM
PSU: Seasonic PRIME 1000
Mon: Philips 346B
GPU: Asus Turbo Series RTX 3080
Sound: Bose 700 Headphones
Case: Asus TUF GT501
Storage: 2x Samsung Evo 980 Pro 2TB (Each, total of 4TB) in RAID 0
Cooling: Asus ROG LC 240mm and a bunch of Noctua fans
https://linustechtips.com/topic/1261319-please-help-me/#findComment-14147473
1 hour ago, Lil_Uzi_Per-Vert2 said:
I was so close. It said this might take several minutes then it blackscreen fml
It sounds like you might have a hardware issue.
If you built this, i would start with reseating everything including the memory and CPU.
Remove any periphials while you do the install also. Any USB other than keyboard and mouse.
No speakers or anything else but the monitor, mouse, and keyboard. Well, and the USB key for installation.
After reseating everything, clear the bios and then reboot.
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
https://linustechtips.com/topic/1261319-please-help-me/#findComment-14147728
Still doesn't work :( am I doomed?
https://linustechtips.com/topic/1261319-please-help-me/#findComment-14151191
