Budget (including currency): 2.5K USD
Country: USA
Games, programs or workloads that it will be used for: Windows, Battlefront 2, Warframe
Other details Already have an EVGA 1080ti ftw3 and LG GL850b
CPU: Intel Core i9-9900K 3.6 GHz 8-Core Processor
CPU Cooler: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Storage: Samsung 980 Pro 500 GB M.2-2280 NVME Solid State Drive
Storage: Samsung 860 Evo 2 TB 2.5" Solid State Drive
Power Supply: EVGA SuperNOVA G3 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Keyboard: Logitech G PRO RGB Wired Gaming Keyboard
Headphones: Sennheiser HD 660s
Dac/amp: Schiit Hel
Hello! I am planning on building my first PC soon and I need some tips/advice. I already own an EVGA 1080ti ftw3 and 27" 1440p 144hz LG GL850b that I will use for this build. I am soliciting advice for the motherboard, RAM, and case specifically but I am welcome to any advice anyone is willing to give. I have no requirements for the RAM or motherboard other than that the motherboard has reinforced pcie slots. The case I would like to be a mid tower with all metal sides, no glass, because I need to be able to transport the PC with having to baby the glass sides.
Thank you for any and all advice!
Jeoxor
https://linustechtips.com/topic/1259938-first-custom-pc/
I would sell the GPU, since you could get a 3080 in s 2500$ build. also, I would wait for next gen amd processors.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135678
I will most likely get a 3080 when they are in stock, but until then the 1080ti is enough for what I need.
Do the next gen amd's look promising? I don't keep up with the market.
Thanks!
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135698
Thanks!
yeah, they do. Very. So pc-gpu for 2.5k?
Bios database
prior build:
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135699
got called out for having this aio. from my experience, it works well but what do i know.
why? if you wont go amd, atleast go with a 10th gen intel cpu.
overkill.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135700
8 minutes ago, eeeee1 said:
overkill
You can never have too much ram. Endless 👏 possibilities
春の八王子、君はもういない。独り八王子、君はいないから。春の八王子、君はもういない。独り八王子、君はいないから。
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135716
overkill.
lol I was not aware the 9900k wasn't current gen. looks like I have some research to do. Also Im not opposed to amd I just liked the 9900k more than the 3800x
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135728
for only battlefront 2 and warframe? even if he was to cut some frag vids together, 32 gigs is still overkill
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135731
Hows this?
32gb of ram
(get the 5900x not the 3900x)
better liquid cooler
fully kitted out meshify c (you can get the clear side pannel version if you want)
2tb of pcie gen 4 storage and 4tb of 7200rph hdd
I didnt put the headphones in, so I put it at 2k, since they cost 500$ (wow, thats a lot for some headphones)
Bios database
prior build:
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135748
Star Citizen* lol
Not really, not for long. Adds stability to games - you'll never be unstable again.
If we're talking about video rendering, then yes. Saving 6 minutes is not worth it.
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135773
15 minutes ago, Jeoxor said:
I use chrome so I want to be able to open more than 4 tabs lol
Lets make him angry, get 64gb 🔪
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135777
8 minutes ago, HelpfulTechWizard said:
Hows this?
32gb of ram
Thank you I will give the case and amd cpus a hard look.
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135788
11 minutes ago, MewMew said:
Star Citizen* lol
um i dont know about you but i could run games very stably when i had 16 gigs.
also:
you arent making anyone angry. just ruining your image to me. your pfp and sig dont help either
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135829
you can run like 3 4k videos and have more google tabs then you would ever want with 16 gigs. if you really needed more, i would think chrome books would come built with 128 gigs of ram
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135834
i can vouch for the cpu. excellent choice.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14135837
1 hour ago, MewMew said:
I'm being friendly calm down.
when you dont even dare to quote.
Ironic Starwars GIF - Ironic Starwars Chode - Discover ...
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1259938-first-custom-pc/#findComment-14136093
