Finding car using it's GPS
Go to solution Solved by WereCatf,
23 minutes ago, ScottDurkin said:
I was wondering is there a way I could see the location of my car using the GPS within it?
Only if the car transmits its location. Being able to receive GPS-coordinates doesn't mean the car transmits its own.
Hi all,
I'm not sure if this is the right place to post but it involves some programming.
My car has a GPS dongle built into it an I can view the GPS settings, coordinates etc etc.
I'd like to make an application where I can ping it's location in the event of been stolen
and track down where it is.
Thanks in advance
https://linustechtips.com/topic/1259303-finding-car-using-its-gps/
You're typically not going to have access to this data.
You can install a separate GPS tracker though...
F@H
GPD Win 2
