Hello ive recently encountered an issue where my mobo light will flash on(blue) for a split second and the off again. After unplugging everything even reseting the cpu it was still showing the same results. After I tried to reconnect everything one by one, changing PSU.
Finally I redid the front panel and now the light is red idk what is going on
Mobo is B450 Aorus elite
https://linustechtips.com/topic/1259211-mobo-issue-not-sure/
What's that tick sound?
https://linustechtips.com/topic/1259211-mobo-issue-not-sure/#findComment-14129502
Does your PC work/boot? You can disable this in your BIOS or download the gigabyte Fusion (I think thats Gigabytes bloatware) app to control the RGB lighting.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1259211-mobo-issue-not-sure/#findComment-14129503
Alright so it's happened again I'm unable to start up my PC, YAY T_T
Sunday after messing with it for 5 hours it magically started to work and I didnt know what I did right
Monday same issue but after I reset the Ram and reconnected the SATA cables it booted
Today(Tuesday) surprise and I've done the same thing. Took apart everything and reassembled it.
After talking with a friend it might be that my CPU is overheating Ryzen 5 2600 (I know its not the greatest im broke)
TL;DR
PC wont start, post, boot
I've reassembled from scratch
Might be CPU
I'm lost
https://linustechtips.com/topic/1259211-mobo-issue-not-sure/#findComment-14135839
