GPU hitting power limit, question
Go to solution Solved by Hairless Monkey,
15 minutes ago, code99 said:
So, other than afterburner, anything else i can do?
Technically yes, there are a few things you can do to increase the power limit. But they are all rather complicated for a beginner and for 99.9% of people it is not worth it. I think you can be happy with the performance that you are getting. If not, a CPU upgrade would get you a noticeable amount of extra performance from the RTX 3080.
Hi
I have an RTX 3080 (ASUS TUF OC model)  and while playing red dead redemption 2 (the most demanding game i have) I see that my gpu utilization goes to an average of 80% but my powerlimit is maxed out.
Is there something that i can do about this?
I've already set afterburner powerlimit as high as it can go which is 110%
Temps are as follows (averages):
GPU - 65 degrees
CPU - 68 degrees
My cpu is a bit outdated, its an i7 4970. I used to have bottlenecks with this cpu the past few days but it ran with the stock intel cooler and its temps were always at 100 degrees and 100% utilization. I slapped a noctua nh d15 cooler on it (i had it bought for my upcoming cpu upgrade) and now the temps are more than fine (less than 60 degrees) and utilization roughly at 80% average.
Anyway, my point is, im curious about gpu powerlimits. I never overclocked anything in my life, this being the first time i even care about it.
PS. Sorry if i ask some stupid questions but hey, i gotta start somewhere :)
https://linustechtips.com/topic/1257646-gpu-hitting-power-limit-question/
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Yeah a cpu upgrade is coming next month with amd's new lineup.
As for gpu powerlimit, i know there were some mods you can do (like physical mods on the card itself) but thats not something im interested in doing. Was hoping that tehre were some software thing i can do otehr than afterburner :)
Thanks!
Well there is. You could flash the card with a vbios with a higher power limit. But you could brick the card.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
Shouldn’t have an issue flashing. Quite rare to have an issue. That along with a shunt mod are the only fixes.
But even if you flash it, you can hit power limit. You can have the bar go to 200% isn’t a guarantee fix.
Can overall cause stability issues as well.
Wouldn’t worry about it myself, running the card cooling will yield more performance than raising the power limit will.
