Hi guys, been folding every day and night on my desktop the last couple weeks, but I'm having trouble getting OpenCL shit to work on my server. It's now running Arch, and it has an R7 370. AMDGPU is enabled and running, and I've tried both OpenCL-AMD and OpenCL-Mesa to no avail. I've attempted to have F@H automatically pick a GPU by setting "gpu" to "true" in config.xml, and I've also messed around with the GPU index (everything from -1 to 2) but nothing works. I did not have this many problems on my desktop (also Arch but with a 570). Not even reinstalling F@H and OpenCL packages helps. Any ideas? Thanks!
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/
Did you install the openCL dev (ocl-icd-opencl-dev) packages?
Did you try replacing the init script and making the folding uid part of the video group?
6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; MSI RTX 4070 ti Super; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Pop Silent XL; Gigabyte Aorus z570 Master; Ryzen 9 3950x; AMD Wraith; 2 x 16GB DDR4-3200; 256GB NVMe; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Gaming X; Corsair RM750e
dcn04: Fractal Define S; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; ; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Ventus 2; Corsair TX750M
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14115773
I'm assuming you mean ocl-icd, and yes, I did.
No, and if it helps at all, I didn't need to on my desktop. I can try it though.
SPECS:
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14115877
I'm not certain if the package names are the same under Arch as they are in Ubuntu but under Ubuntu you need the development packages for OpenCL not just the stock implementations.
WRT privileges it appears Arch also needs the folding client user to be a member of the video group
Systems:
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14115913
@Gorgon I tried adding FAHClient to the video user group, but it seems there is no FAHClient user (or foldingathome).
EDIT: I also tried adding myself to video group, no dice.
SPECS:
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14115929
under ubuntu the uid is "fahclient"
Case may be important. Try:
getent passwd | sort
to display a list of all configured users
Might be "fah" on Arch.
Systems:
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14116262
It was fah, not fahclient or something, but still not working after adding to video group.
SPECS:
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14116359
I also saw some references to the fah user needing to be owner of /etc/fahclient/* and some other folders (/var/lib/fahclient ?) on the comments for the Arch Package
Due to these kind of issues I've left all my folding systems on Ubuntu 18.04 LTS Desktop as I know how to get that working. I've tries 20.04 a couple of times but was never able to figure out exactly what I did to get it working.
Hopefully the newer client when it gets completed will fix a lot of these issues as the current one is showing its age
Systems:
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14116373
Well it wasn't working on Ubuntu either and it was much less of a pain to set up on my desktop (just OpenCL, F@H itself, boom done). I dunno.
SPECS:
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14116399
Depending on the errors you get (you can find them in /var/log/foldingathome/log*.txt), you may need to do some extra steps to get these early amdgpu-module-compatible graphics cards folding. I posted my findings in Metallus's guide here:
Hope it helps with your card.
CPU AMD 7800X3D | Cooling Noctua NH-D15 chromax.black | Motherboard ASUS PRIME X870-P WIFI | RAM Corsair Vengeance RGB 6GHz CL30 32GB | GPU EVGA GeForce RTX 3070 FTW3 Ultra Gaming |
Case Fractal Design Define R5 | Storage Samsung 980 PRO 500GB, Samsung 970 EVO+ "v2" 2TB | PSU Corsair RM850x 2021 | Display ASUS VP247QG + Samsung SyncMaster T220 | OS CachyOS
https://linustechtips.com/topic/1257573-bad-wusopencl-problems/#findComment-14120885
