Lets say I have a 800watt PSU. Using 80% efficiency, it means that at Max the PSU will draw 1000watt power from the wall socket.
Lets say I connect it to a 500watt UPS. This means that during power outage and the UPS battery kicked in, my PSU will only able to draw 500watt of power.
If it takes more than that (during gaming/other heavy load), the UPS and PSU will shut down.
My question is:
When it's NOT during power outage (power is running normal from the wall), how many watts does my PSU able to draw?
Is it 1000watt? Or is it still limited to 500watts of power from the UPS socket even when it's not on UPS battery?
Might be a dumb question, but I need to know :D
Thank you.
https://linustechtips.com/topic/1257447-question-regarding-ups/
In most UPS-es the rated power isn't just when on battery, my 480W 800VA UPS was too weak for my old system at the time (FX 8300, R9 380X, 550W PSU) and during gaming it sounded the overload alarm. So the 500W UPS would do while in idle or regular web surfing, but it wouldn't hold for gaming for you.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1257447-question-regarding-ups/#findComment-14114742
Quote
So it might differ from model to model? Is there a way to check this?
By your answer, it would seem the UPS is the "true" limit of the power instead of the PSU (if the ups watt is lower than psu watt). Many guides I read about UPS suggest to use the normal/average power you use instead of max psu watt. If what you're saying is true, that would make many PSU with higher watt even more useless
https://linustechtips.com/topic/1257447-question-regarding-ups/#findComment-14114755
