Greetings, I am looking to buy a new laptop exclusively for UNI related stuff (video conference and document work) I have a high end desktop so I wont do any gaming at all on it.
I am thinking a good cpu one (hate when its not a smooth experience)
Good screen and good battery life are the 3 priorities.
My budget its around 1k but will be highly appreciated way cheaper suggestions.
If this may help I am planning to install linux on it so it runs even smother and lighter.
https://linustechtips.com/topic/1257310-help-choosing/
For 1K you can get a Ryzen 4500u or 4600u.
For your requirements i think a Ryzen 4300u is more than enough, from $500.
Take a look at Huawei matebook with ryzen 4th gen 4000, they are the best bang for the buck.
https://linustechtips.com/topic/1257310-help-choosing/#findComment-14113592
