Budget (including currency): 700-900 CAD
Country: Canada
Games, programs or workloads that it will be used for: Gaming at 1080p (CoD, Dark Souls 3).
Building a PC for a buddy with some parts I have laying around. I have been out of the new PC building game for a year now so open to AMD suggestions as well. (My last build was 3 8700k gaming pc's).
PC Parts I own and WILL use in the build to cut down costs:
GPU - GTX 1660 Super
PSU - 850 Watt Gold+
SSD - 1TB Samsung evo 850
HDD - Slapping in a WD 4tb drive
Throwing in the mouse + keyboard + 1080p 27inch screen I have laying around.
Looking for: Mobo + CPU + (Cooler?) + Ram + Case suggestions
This is a gift and I would like to stay at 700$ CAD but can go as high as 900$ since I can collect some extra scratch from his other friends to help contribute to the build.
Any help is appreciated. Thank you!
https://linustechtips.com/topic/1257155-building-a-pc-suggestions/
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Country: Canada
You will have to decide about the size...
If your friend only needs one graphics card, you could go with ITX and a small case (also depending on the size of your PSU)
µATX is usually the cheapest form factor because it is sold the most.
The case is a lot of personal taste. Personally I like the design of the Phanteks Evolv Series and I use a fractal design define R6 myself. Both good quality cases. The R6 is pretty subtile and really flexible for different builds. The Evolv has a more impressive design. Also a big 200 mm front fan for silent airflow.
You might want a case with USB C, since it is a fast way to transfer data to and from modern devices.
CPU cooler is the old fight air cooling vs watercooling. Personally I go for air cooling because in a lot of reviews air cooling is really silent and still good cooling and all you have to do for maintenance is blowing out the dust.
For air cooling the be quiet! Dark Rock Pro 4 is a popular cooler. It works for both, Intel and AMD.
About RAM: For an office PC 8 GB would be enough and since you are going for some gaming, 16 GB should be enough for most games. If you go for Intel you will need a Z mainboard to be able to overclock your RAM.
MOBO and CPU: Make sure it supports USB-C if you want it for your case. Overclocking, or not? Intel or AMD?
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
