Hello, I was wondering if it was weird if I didn't see much of a change in CPU temperature's when running my X60 with different fan speeds. Getting around 30-35 Celsius settings set at Extreme vs Silent with no games running. With games running around 38-42 Celsius with the same scenario.
Is it normal for Ram giving off large amounts of heat when playing games?
Desktop: Intel 4770k - 12GB Vengeance Pro 1866Mhz RAM - Asus Maximus VI Formula Mobo - Asus Strix 970 SLI - Cooler Master V850 PSU -  Nzxt Phantom 630 Case  - 1TB WD HDD - Samsung 840 Evo 250GB SSD - Nzxt Kraken X60 - 24" Asus VG248QE 1080p Monitor - Logitech G35 Headset -  G502 Proteus Core - Logitech G710+ Keyboard - Nzxt Hue - Windows 10
https://linustechtips.com/topic/125651-questionissue-with-cpu-cooling/
ram heats up in all situation just depends on what your using it for, editing/gaming its going to be warm browsing it wont warm up that much
Specs
That seems reasonable, would you happen to know what the issue is with the cpu temp?  To me it doesn't seem normal as I would just keep it at the lowest speed. In reality however higher speed seems like it would lower temperature.
the nzxt drivers have always been buggy id message them and give them a heads up just set it to silent i guess its quiet and your getting good temps so its a win win :P
Specs
I was looking at temps from core temp, but if 30-35 with browsing & 38-42 with gaming is good then it seems fine.
often a higher fan speed in liquid coolers only shows much of a difference if you run a torture test and over clock your cpu. better cooling never was really beneficial unless you overclock. Also if you have the standard fans on the cooler, to be fair, they are not the best pressure fans. If the static pressure is too low and if the fan spins up the airflow through the radiator will not increase. But as long as you have those temps just leave the fans on quiet
