So I've been having a WW2 crave these lasts couple of weeks and re-downloaded BF5. One thing that I noticed is how bad the FPS is, not only compared to other games but compared to the launch of BFV. Any tips to improve it? I have all the settings on LOW, DX12 turned on or off doesn't change anything for me, GPU memory restriction off. Basically as low as I can make the game.
I am playing at 3440x1440 and the game barely hits 80fps
In BF1 I get 130+fps with a mix of high and medium
BF4 180+fps almost maxed out
Specs:
Ryzen 7 2700x @ 4.2ghz
RTX 2070 (normal)
16GB DDR4 3200mhz Ram
game is running from my HDD but that shouldnt impact it that much.
https://linustechtips.com/topic/1256463-low-fps-in-bfv/
Specs:
RTX 2070 (normal)
Is that 1440p you are running it at?
Just that I heard BF5 was quite a taxing game to run, and i would have thought 80 fps was reasonable.
Then i re-read your post and saw that you had turned everything down.
What fps would you get if you turned everything back up to high and/or ultra?
https://linustechtips.com/topic/1256463-low-fps-in-bfv/#findComment-14106425
Around 60fps, not a lot less/
https://linustechtips.com/topic/1256463-low-fps-in-bfv/#findComment-14106481
