Do you need it now? If not, wait for Zen 3 and new GPUs.
CPU - Ryzen 5 5600X | CPU Cooler - EVGA CLC 240mm AIO  Motherboard - ASRock B550 Phantom Gaming 4 | RAM - 16GB (2x8GB) Patriot Viper Steel DDR4 3600MHz CL17 | GPU - MSI RTX 3070 Ventus 3X OC | PSU -  EVGA 600 BQ | Storage - PNY CS3030 1TB NVMe SSD | Case Cooler Master TD500 Mesh
https://linustechtips.com/topic/1256365-plase-help-me/#findComment-14105631
7 minutes ago, RAM555789 said:
I would wait, less than a month till GTX 3070 (October 29th) and Ryzen 5000 (November 5th)series comes out, there is zero point in buying right now.
Do you know how much the 5000 series will be? also im pretty sure i can only buy this stuff on pccasegear (its a australian website) my parents just making me get off there but if i get it from different sites it would be so much cheaper
https://linustechtips.com/topic/1256365-plase-help-me/#findComment-14105646
https://linustechtips.com/topic/1256365-plase-help-me/#findComment-14105650
11 minutes ago, Healyz said:
i dont need it now but in the next month or two cuz im desperate lol. how much will 3070 and 5000's be? aud btw
3070 will be $809 aud and 5600x will be $420 aud. I would suggest waiting for lower end parts such as the 3060 and 5600 non x
https://linustechtips.com/topic/1256365-plase-help-me/#findComment-14105663
6 minutes ago, Healyz said:
do u know when the 3060 and 5600 will release
3060, probably by January 2021, as 2060 was released January 2019. But don’t rule  out an earlier launch if AMD is competitive. As for the 5600, that ones more of a guess, probably at least after the Nov. 5 launch of their x series.
https://linustechtips.com/topic/1256365-plase-help-me/#findComment-14105691
alright thanks so much
https://linustechtips.com/topic/1256365-plase-help-me/#findComment-14105694
If you can't wait here a decent build you could go for. I would avoid trying to buy all your parts from one site, you can get much better pricing by comparing and shopping for deals across multiple sites. PcPartPicker.com does a lot of that work for you already however you can always compare the prices you see with that on pcasegear. Also November 27th is black friday, not sure how big it is in Australia but I'm assuming you guys get some pretty sweet deals as well, so that should be a pretty decent time to look into building as well.
https://linustechtips.com/topic/1256365-plase-help-me/#findComment-14107104
thanks, i didnt think about black friday. i can only assume that there will be some discounts, appreciate it
https://linustechtips.com/topic/1256365-plase-help-me/#findComment-14111628
