Hullo,
I have two questions, Firstly:
I've been looking for some good wireless powered speakers for under $300. So far I've found This  and this . Which one is better? are there any better speakers out there?
TL;DR: I have a pc in the center of my 65' inch desk, and a printer to the right. I have a desk shoved in the corner, and basically no clearance to the back of the desk or the right of it, but I can change the position of my desk if needed, but I don't want to. I want to have a sub, and if so where should I mount it? I can wall mount it, put it to the right of me (in the corner), or on the right of me. Without a wall mount I won't be able to center it. What should I do?
Secondly, If I get a 2.1 sounds system, or something like that which has a separate sub, where should I put it? I have a desk setup with a 65' x 30' inch rectangular desk. I'm planning to put my speakers on either side of my all in one pc (Imagine an Imac running windows). I have a printer taking up most of the space to the right of me ( ~15'x15 it's pushed to the back of the desk), my pc (~22' x12) and nothing to the left of it (Roughly 22 inches of space on either side of my pc). My desk is right up against a wall and a corner (on the right of my desk) can't place my behind my desk unless I wall mount, which would put it above my other speakers. I only have about two inches of clearance from the back of my desk to the wall, and four inches to the other wall in the right corner of my desk. I can move it to the right or back if needed, but I don't really want to do it  My desk has a privacy wall underneath it, and drawers on both sides of the opening for legs. Because of those two things, I won't be able to place my sub beneath me. Should I wall mount the sub, put it to the right of me (on the corner), to the left of me, or is there somewhere else I can put it?
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1255919-need-help-with-speakers/
