Posted October 7, 2020 Hey! So I wanna upgrade my gaming headset since my current one is pretty bad but I'm not sure which one to buy. I'm thinking about buying either the Logitech G Pro X (I have a coupon for the Logitech store so I get it for $110) or the Cooler Master MH751 or the HyperX Cloud Alpha S. Which one would you suggest and why compared the other headsets around under $110? I will be using it for gaming on my pc and casually just listening to my music on my phone or pc so I wanna be able to wear it in public. If you do recommend something that’s not the g pro x, mh751, or the cloud alpha s: I'm only looking for recommendations for closed-back headphones with a solid microphone (so it doesn’t sound like there’s a hurricane going on in the background when I talk in zoom calls or discord etc), good sound quality, and comfortable enough to wear for hours and hours of zoom calls for school and long gaming sessions. Thanks! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
